budget swap
import92c
I search and couldn't find any information on this topic, but I am sure someone has done this swap before...My friend and I are swapping a GS-R motor into a LS integra. Everything bolted up properly and is hooked up. The only problem we are running into is the car's wire harness has a extra plug but the motor doesn't and we aren't really sure what the extra plug is....vtec? If anyone knows please helps out with links, etc hook it up correctly. Thanks in advance
what color are the plugs? better yet what color are the wires and look it up in the reference part of this website and you should be good from there
