Build Being Put Together As You Read! :)
Discussion in 'Forced Induction' started by Boosted4Life, May 30, 2010.
  1. Boosted4Life
    Boosted4Life New Member
    Ohio
    94 Civic Coupe
    Gutted trunk otherwise full interior
    -B18a1 block
    -ARP Rod Studs
    -New OEM Rod Bearings
    -B18a1 Head
    -New Valve Stem Seals
    -Crower Dual Valve Springs/Retainers
    -Crower 404's
    -Skunk2 Cam Gears
    -Skunk2 Cam Seal
    -ARP Head Studs
    -Cometic HeadGasket
    -Hondata Intake Mani Gasket
    -Stock Intake Mani
    -Revhard Turbo Kit
    -Custom Dumptube
    -Log Style Mani
    -Garret 60 trim
    -TurboSmart Wastegate
    -Hallman Boost Controller
    -Custom DownPipe
    -Large Ebay Front Mount Kit
    -Resurfaced Flywheel
    -Exedy Organic
    -Chipped P72
    -Walbro 255
    -Short Shifter
    -AEM Wideband
    -Boost/Oil Pressure Gauge
    -3 Gauge Pillar Pod
    -C&R Half Radiator
    -Thermal Exhaust
    -Drilled Rotors on front
    -Slotted Rotors on Rear
    -Tokico Struts/Coilovers
    Exterior
    -New Front Bumper
    -Type-R Lip
    -New Rear Bumper
    -New Fenders
    -New Hood
    -New WindShield
    -New Rear Quarters
    -Carbon Fiber Fuel Door
    -New Nitto Neogen's
    -I believe Drag DR-21's painted bronze
    -Ran out of money so going black primer for now and stock injectors, going to run probably 6 lbs until new injectors.
    Probably forgetting stuff.
    What do you guys think?? Will get pics up as soon as i take some more!
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Sounds like a decent turbo build. PICS!
  3. Matts96HB
    Matts96HB . Moderator VIP
  4. 95b16coupe
    95b16coupe New Member
    ct
    is this going to be a dd or track only car?
  5. 99sidude
    Ohio
    sounds like a cool build. where in OH are you?
  6. eg6sir
    damn, you must be tired if you're still building.. i'm just reading this
  7. Magana559
    Magana559 The Warden
    fresno Ca
    404's with boost??
  8. Boosted4Life
    Ohio
    It's going to be my dd and yes 404's with boost. I heard it can be a pretty sick set-up and the motor is finally together. sounds great, havn't driven it yet, trying to find a tranny, not that i really need one, mine just grinds going into 3 every once and a while. And im located in Loudonville, OH. It's about 30 min from Mansfield.
  9. Boosted4Life
    Ohio
    it's also possibly for sale....want a diesel
  10. Boosted4Life
    Ohio
    Also just bought a set of Precision 680's and put new lower and upper balljoints!
  11. RickParker
    RickParker New Member
    Shippensburg, PA
    sounds like a decent build.. wheres the pics?
  12. Boosted4Life
    Ohio
    Tryin to find the cord to upload lol ive taken prlly 25-30 ill get them up as soon as i can...sorry guys
  13. Magana559
    fresno Ca
    404s have high overlap, im guessing you fix some of that with cam tuning.
    what comp are you running? maybe nice with boosted 10:1 and up.
  14. Boosted4Life
    Ohio
    Just stock LS block which is around 9.2:1 except arp rod bolts...plan on building block this winter.
  15. Boosted4Life
    Ohio
    Got tranny in, now wont start? replaced all grounds. Charged batter. You can hear the fuel pump kick on, then you turn the key over and it just clicks once and nothing. Anyone?
  16. Bobby17772
    Bobby17772 New Member
    Enfield, CT
  17. Boosted4Life
    Ohio
    Got it fixed...starter was seized from sittin for a few weeks. All's good now. Going to try and upload pics!
  18. Boosted4Life
    Ohio
    So i have ton's of pictures but comp won't let me upload..
  19. newb
    newb phresh VIP
    Backwoods Northwest
    No pics = tease.
    Tease = fail.
  20. Boosted4Life
    Ohio
    What's the best way to upload pics??
