Building D16
Discussion in 'Engine Building' started by Drenni, Apr 8, 2003.
  1. Drenni
    Drenni Senior Member
    Just wondering what should be the next step in building the engine??? It's got DC Header, 2 1/4 exhausts, apex pipe, skunk2 cam gear, UN under pulley, AEM V2, EX intake maniflod and AEM fuel regulator. It does pretty good on the street and on the track B). But what should be the next step, I have'nt taking the car to the DYNO yet so what should be next com'on guys let me know :( .
  2. head and fuel
  3. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    n/a = bore + higher compression pistons. + adjust timing
  4. Drenni
    That's all anything else guys, I'm taking it to the DYNO on Friday.
  5. illegal_crx
    illegal_crx Junior Member
    koo
    i got a cute setup too :ph34r:
    :sleep: i got a d16y8 vtec from japan it has a
    aem cold air intake, dc heaters, ngk spark plugs, and wires, 2 1/2 pipeing after market muffler advance timing, high flow catalitic and b&m short shifter
    what you should get is what i want to get
    1 stage 4 or 3 clutch
    2 holley's gas pump
    3 apex- vtec and fuel controller
    4 aluminum radiator
    5 b&m oil cooler
    6 Jets computer chip
    7 tornato
    8 crane cams ignition
    9 cam gears
  6. phunky.buddha
    Dallas / Fort Worth, TX
    1. Stages on a clutch only matter if the manufacturer makes different stages... they mean nothing on their own.
    2. You don't really need a larger gas pump for an all-motor D series
    3. VAFC is good
    4. Aluminum radiator is overkill for that engine... waste of cash there
    5. Same there on the oil cooler
    6. No need for a chip if you're getting a VAFC
    7. Tornado = waste of money, it's a scam part
    8. You can only fit one cam in a SOHC engine, and you don't need to upgrade the ignition for your 0hp in upgrades listed here so far
    9. You can only fit one cam gear on a SOHC engine that only has one cam...
    Welcome to HondaSwap, by the way. Read and learn. :)
  7. Drenni
    :eek: :eek: :eek: :eek: :eek: That was a little tooo much :worthy: , what do you think should be the next step :( . I would like to get down to the low 15's I'm high 15's now <_< .
    Thanks
  8. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i would look into fuel manangement if you are going to dyno.
    get a vafc or some other form of fuel controller and dyno tune it w/ a wideband.
    i gained like 12 whp just by tuning.
  9. illegal_crx
    :blink: dam you made me look stubid
    O well i learned something :D
    but if you get a better radiator and a oil coolor the engine will run a lot coolor right? yes
    so it will be more reliable and it will create more horsepower so why do you say that, those two parts are over kill?
    as for the stage 3 or 4 clutch, i meant get any brand but it better make a stage 3 or 4 clutch
    also what do you think he and i should get to create more horsepower? :ph34r:
  10. illegal_crx
    :huh: as for the chip doesent it make you rev higher
  11. Drenni
    thanks guys, what the hell would I do without you guys :rolleyes: .
  12. sohcslammer
    sohcslammer Senior Member
    Bay Area
    :p You should do what I'm doing. Admit defeat and buy a b-series. You can never make a d-series as fast as you want it (as fast as I want at least) I'm running a D16z w/ aem cold air, DC 4-1, DC cat back, spoon chip, aem CAM gear (yes, there IS only one :p ) DC short shifter, centerforce clutch and it's still slow as shit. (Just about keeps up with my buddy's 4 door gsr w I/E) Even if I turbo this setup and add cams and pistons I'm still better off swapping in a b18c1 with some bolt ons. <_< Fuck this sohc shit.
  13. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    yeah if you have the money go for a b-series(b16a or b18c). but your best bet for more power for your d is larger bore, higher comp. pistons, and port and polish.
    no chips dont make you rev higher, tuning and the absence of a rev limiter makes you rev higher. you dont always benefit from revving higher anyway.
    an d15 and d16 doesnt get very hot so you wouldnt need an aluminum radiator, plus you cant run "cooler" if you're already running it as cold as it can, which is ambient(spl?) temperature.
    different manufacturers make different torque range for the same stages of other brands. eg. brand a; stage 3=220lbs torque, brand b; stage 3= 300lbs
  14. Drenni
    :huh: :huh: Well let me tell you a little story my brother has a H/B Civic 96 with a EX tranny and some other minor modifications (mini-me) and is running in the very low 15's (15.2sec) to be exact, I don't think that's bad at all but I have seen D engine's hit the 14 sec N/A :worthy: :worthy: believe me it's kind oh hard to get a B series down here in PR ($$$$) they want an arm and a leg for the engines.... :angry: .
  15. solblu
    solblu Senior Member
    Ricer
    Next step EX tranny, B series TB port matched to IM and then take it apart and put in some P29 pistons, a Cam from http://www.deltacam.com/index.htm and some headwork.
