bulb replacement
scomstock55
How do I replace the front drivers side turn signal bulb in a 2001 Accord EX V6
pop the hood and look behind the headlight.. locate corner bulb socket and twist.. then pull out and remove old bulb.. place new bulb where old bulb was.. reverse steps
if it was that easy I wouldnt have posted a question...the turn signal light and its socket are located at the extreme outside position of the headlight...it cannot be reached from under the hood...
take the phillips head screw out and take the whole light out. then turn remove the bulb.
DONE !!!!
