CA BAR: FAILED; 92 Vx with 95 B18c1
Discussion in 'Civic and del Sol - EG and EK' started by rhymeshark916, Jun 10, 2011.
  1. rhymeshark916
    rhymeshark916 New Member
    Sacramento, CA
    Hey everyone. New to this site. I just signed up. Failed smog trying to BAR my Civic. Looking for answers that I'm not getting from H-T. Thanks to everyone for their help. Please no HATERS. Keep your negative comments out.
    Engine breakdown:
    95 b18C1(100 miles)
    B16 tranny
    CTRcams
    USDM ITR pistons
    DC header 4/1
    GSR Magnaflow catalytic convert(crappy)
    ITR B+pipe w/muffle
    stock RS intake pipe with old/dirty filter(no box)
    new ngk bkr7e spark plugs & wires(I didn't gap, just slapped it in)
    new ntk/ngk o2 sensor
    17' btdc
    Stock P72
    HC CO NO
    127/301/242 0.79/2.29/2.42 825/2039/150
    101/251/3.14 0.68/2.18/3.14 764/1839/113
  2. eg6sir
    first off you're going to need a good cat.. what was your HC reading? i cant tell from how you typed it out
  3. rhymeshark916
    Sacramento, CA
    HC
    127/301/242
    101/251/3.14
    I didn't type it like that. It just happened.
  4. rhymeshark916
    Sacramento, CA
  5. rhymeshark916
    Sacramento, CA
    Never mind the numbers from the first post.
  6. Matts96HB
    Matts96HB . Moderator VIP
  7. eg6sir
    like I said before.. need a good cat or the numbers are only going to continue to get worse
  8. UNDR8D
    UNDR8D ...has a job!
    8OH!5
    What makes you say the Magnaflow cat is crappy? That is all we install here and they are one of the nicest aftermarket cats I have seen. Where in CA are you?
  9. eg6sir
    guessin Sac by the ref location on the smog sheet.. lol.. if the cat is old and worn its crappy and no longer functions correctly
  10. UNDR8D
    8OH!5
  11. rhymeshark916
    Sacramento, CA
    Brand new and I know it is shitty. Can't compare to OEM. I'm going to have to say it's not the "nicest" either.
  12. UNDR8D
    8OH!5
    Well the Magnaflow cat is the next best thing to OE, although, it may not be a California compliant cat. When we look up cats for vehicles, we have to select the California only online catalog. Someone may have used the 49 state cat, which will fail California emissions.
  13. eg6sir
    yep.. the CA one costs much more than the rest
  14. rhymeshark916
    Sacramento, CA
    Update:
    Pulled the header off and there's oil in the two middle exhaust ports.(3 &2?) F*cking bad valve seals. Even though it is brand new with new valve guides.
  15. rhymeshark916
    Sacramento, CA
    UPDATE: New GSR swap. Didn't change a thing but using my spark plug wires, O2 sensor and Magnaflow Cat. Here is the result. Obviously, how do you lower the HC now?
  16. eg6sir
    how old is the o2 sensor?
    its the sensor or the cat ..
  17. rhymeshark916
    Sacramento, CA
    :mad: :mad::mad: New with the fresh build on the other motor with just a little over 100 miles. I think the O2 is not working properly or just suck for $50.
  18. eg6sir
    when i was trying to BAR my EG i kept failing the HC test too.. sent it to a family friends shop for diagnosis and it was the o2 ..
  19. rhymeshark916
    Sacramento, CA
    Well the one I have is practically brand new. It might be f*ked up due to last motor running super rich. I don't really know. NTK/NGK what not.
  20. eg6sir
    hmmm... not sure.. have a smog diagnostic done on it.. only thing i can suggest to do instead of spending a bunch of money on parts you dont need
