Cai Made Of Pipe
Discussion in 'HYBRID -> EG-EK / DC' started by stock88civic, Jan 17, 2003.
  1. stock88civic
    stock88civic Member
    MN
    ANYONE KNOW how to make pne out of pipes from a hardware store and a K/N style conical filter a link to a how to would be great.
    also is there any way to chip my pm5 ecu
    if I do a mpfi swap from my 86 teg to my 88 civic is there a way that I can use the pg7 ecu from the teg when I do this swap.
    THANKS IN ADVANCE MAASSAS OF HONDASWAP
    :worthy: :worthy: :worthy: :worthy:
    :ph34r: :ph34r: :ph34r: :ph34r:
  2. SolReaver
    SolReaver Senior Member
  3. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    I think you can use the PG7 ECU with the injector swap--just make sure to get an Si distributor like I told you before. The Integ cyl pos sensor is on the exhaust cam, whereas the Si is in the distro. Haven't I told you this before?
