calculating head gasket thickness
RED_95_GSR
i am using arias pistons with a 3.205" inch bore and a head cc of 41.6
when i calculated my head gasket thickness to achieve clearance it came out to .3146.
i had planned on using a multi-layer cometic head gasket, but they come in .30.
so, do i need to special order a head gasket witha thickness of .314? or, can i just order one that is .32 and have a little extra clearance?
does anyone have any suggestions on a head gasket brand? i just have heard good things about cometic and had decided to go with them..
thanks
also, when rebuilding what is a quality company that makes a full gasket kit for a b18c1?
Cometic is a great gasket maker- just ask them for a custom thickness gasket and they can make whatever you want, even up to .5 if you really need it.
Originally posted by 97CTR@Jan 17 2005, 04:13 PM
I beleive that a stock gasket is .026 if that helps.
[post=446988]Quoted post[/post]​
.029 inches... I think he was calling out measurements in millimeters.
