Camshaft ID question
Discussion in 'Engine Building' started by clanny, Mar 18, 2005.
  1. clanny
    clanny Member
    Scotland
    I have bought an imported b16b and took the cover off to install skunk2 cam gears and a new timing belt. When I was in there I noticed that the springs and retainers all appear to be titanium.
    This got me thinking. Surely no-one would go to the trouble of replacing them without replacing the cams too? Now what I'm wondering is, is there any easy way of identifying what cams are in there?
    I guess, at the end of the road, it won't make a lot of difference when it comes to tuning it because it'll still be a case of dialling them in but it will make a difference if I ever want to skim the head or increase compression. Or want to sell sometime in the future.
    Thanks for reading.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Well, they mod in Japan too, so there's a good chance that the cams are aftermarket.
    As far as identifing them, well, you'd have to get with some manufacturers, or search the net for a collection of markings.
  3. 97CTR
    97CTR Senior Member
    What makes you think that the retainers are titanium? If the cams are stock they will have one ring "engraved" on the end of the cam a little less than an inch down. Or its two rings depending on the year, I think.
    Pic
    or look at the top of the forum at itr cam fraud for pics
  4. clanny
    clanny Member
    Scotland
    Ok, an update. Firstly, thanks for the shortcut - very helpful (would be even better if the pictures were a little lighter but good just the same).
    I checked on my cams the inlet has the letter K cast into it and the exhaust has the letter L. This differs from that thread so I saw wondering. I called up my mate who has just bought a set of b16b cams and his said B and D.
    I started sweating in case I had been done and had a set of b16a cams in there or something, so, off with the dizzy and the cam covers and holder and saw that the cam has the two grooves at the end. Whew, sweat over. Looks like it's all stock b16b cams after all.
    The reason that I reckon the springs are titanium is because they look like titanium. I'm fairly good with my metals because I deal with stuff like that at my work but without taking them out and inspecting them I can't be sure(and I don't want to take them out). The exhaust ones have blue paint on them and the inlet ones have yellow. Does anyone recongnise this colour scheme? Is it honda standard?
    Anyway, thanks for your help guys. :worthy: :D
  5. cws13
    cws13 Senior Member
    Athens,GA
    Yes, those are OEM Type-R valve springs.
  6. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    well yeah, he said it was a B16B...it's a CTR motor
  7. clanny
    clanny Member
    Scotland
    OK that's cleared all that up for me. Cheers for the replies guys. I guess the titanium colour is down to the surface texture of the metal of the springs.
