Quoted post[/post]]
Aren't you the guy with the rod knock? I wouldn't drive it b/c of that, not the cps code. The cps code won't make your engine explode. May cause it to not run though. Depends on why that code is set. Don't be shocked if it stalls and won't restart.
Quoted post[/post]]
Sorry, I was thinking of a different thread. Definitely wasn't you. Back to original question:You can drive it but for how long and how it performs are the real questions. Have you checked and made sure you didn't damage or disconnect any wiring at the distributor?
