can it take it???
yes it can. i'd go with a t3 60mm trim on your motor. i assume your motor is stock? 4-9 psi can be run safely on stock internals. tune with some kinda aftermarket stand alone ECU and you could squeeze a little more out of it.
you "could" squeeze?
if you dont tune that engine after you have all the hardware on it, it WILL blow.
^^^ my answer to him was a generalization based on the assumption his motor is stock. offcourse you have to tune that's a no brain'r. just giving him one more option for more boost.
