Can you help me with injectors?
Discussion in 'Civic and del Sol - EG and EK' started by b18b1_delsol, Apr 21, 2008.
  1. b18b1_delsol
    b18b1_delsol New Member
    Ohio
    I am boosting my b18 and looking to run dsm injectors. Do I need to install a resistor pack or is it that I just wire up the plugs? Thanks
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    yes you need a resistor box or to run inline resistors. If they're being installed in an OBD1 del sol.
  3. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    you might want to consider running other injectors... DSM injectors are great, but they only flow 390cc to my knowledge. go through Precision or holley to get them
  4. b18b1_delsol
    Ohio
    But will DSM injectors work for a DD with only 6-7 lbs
  5. turbo sol
    true but a 440 wouldn't have to work as hard as a 390 to push fuel, if that came out right. the workload on the 390 will be higher but a 440 will be at a lower work load and still be supplying athe same amout of fuel.
  6. nootrac22
    exeter pa
    For me, as a general rule of thumb I leave myself room for growth. right now DSM injector might be enough for you, but down the road you might want to do some upgrades to the engine and run more boost, then the DSMs won't be enough. Also use some common sence when doing stuff like this. You will probably never need 1000cc injectors. IMO I'd rather pay a little more once then go cheap the first time, and get the right thing the second time (right dosen't mean being a brand whore either).
  7. b18b1_delsol
    Ohio
    well i bought a set of dsm 450's today and need to buy a set of plugs and a resistor box. Thanks for all your guys help. :)
  8. t3t4delsol
    t3t4delsol New Member
    York, Pa
    dsm off of a automatic are 390cc there red top, the 450cc are blue top off 5 speeds
  9. b18b1_delsol
    Ohio
    yea they are blue tops.
