Can't get the pluggs to fire, any ideas?
Discussion in 'Civic and CRX - EF' started by tricktoyz14, Mar 2, 2009.
  1. tricktoyz14
    tricktoyz14 New Member
    strayhorn, MS
    im about to the end of my wits with this car..
    i cannot figure out why my pluggs refuse to fire,,
    first here is the story of the car,
    i bought a 1990 civic dx with a b18 and an s1 tranny in june of 2007
    i flipped this car in august of 2007,
    the engine was un harmed and still ran like a striped ape..
    seeing the body was totalled i put the engine in a 1989 crx si body i bought from a friend,
    this car had a b16 in it that they had raced.. i believe it had some kind of stand alone computer system in it..
    but i bought the body and put my b18 in it.
    the swap wasnt difficult and i wired the engine up.
    put the computer from the civic, (from a 1990 integra)
    into the crx, and i couldnt get the pluggs to fire..
    i had someone come look at if for me.
    and i didnt have the ground on the back of the wiring harness,
    the one that hooks to the thermostat body,
    hooked up.
    we hooked it up and a few other wires that were loose and the pluggs started firing.
    they did fine for like 3 or 4 hours. just long enought for me to get it started one time
    then they just stopped.
    i redid the grounds like three times.
    replaced the distributor, the rotor button, the distributor cap, and the main relay,
    (the one under the dash on the kick panel)
    but still no fire,
    i have no idea what else to do to get this thing to work.
    its just been sitting for like 6 or 7 months and i want my baby running,
    please if you have any ideas or suggestions anything is greatly appreciated.
  2. ntenc1
    ntenc1 New Member
    Are you using pr-4?
  3. red91efhatch
    red91efhatch New Member
    Albuquerque
    I would test voltage to the distributor, then also test those same wire for any open connections, then test continuity between all wires from the distributor to the ECU. if your ECU is sending power/signal you shouldn't have a problem, I would post the exact instructions but my alldata account expired.
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    chec if your getting spark from the dizzy,if so then replace the plug wires,thats what happened to mine,rplacd them and it ran mint
  5. oneclean89hb
    oneclean89hb New Member
    AKRON, OHIO
    I would of just kept the b16 in it
  6. ntenc1
    ntenc1 New Member
    If you are not using the correct ecu. Your car can run but run like crap. Wait a minute this OBD0 right?
  7. tricktoyz14
    strayhorn, MS
    the two plug wire to the dizzy is getting power, and its getting power out the coil. but if i put a screw driver into the cap where the wire goes out to the plugs no fire.. and its getting fire through the rotor button, everyone has told me to check my grounds..
    the wires are good though. made sure on my cousins rodeo..
    ive got the ecu for the enigine
  8. tricktoyz14
    strayhorn, MS
    and what do you mean about testing for open connections? im really new to the wiring stuff
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    wait under the cap there is a spring looing thing that HAS to be there,,it goes into the cap and touches on the coil,chck if its there
  10. tricktoyz14
    strayhorn, MS
    its a brand new cap.. and you mean the lil piece of metal that sticks out into the coil?? ist there.
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yea its a little metal thing with a spring on it,it has to be there,or you wont have spark
  12. tricktoyz14
    strayhorn, MS
    its there, its a brand new cap.. my fuel pump isnt engaging either.. would that be related?
  13. INJEN78
    INJEN78 HS LEGEND
    OHIO
  14. sevenhillsbilly
    sevenhillsbilly New Member
    those main relays are hard to find in a junkyard and are about 55 at an autoparts store
  15. tricktoyz14
    strayhorn, MS
    i already replaced it.. brand new one like a week ago..
  16. MthaFuknGreen
    Lodi, CA
    is the coil wire plugged in?
    lol
  17. tricktoyz14
    strayhorn, MS
    haha, yes.. someone told me my ignition switch may be out...
    could that be it?
  18. tricktoyz14
    strayhorn, MS
    i put a new ignition switch on the crx,
    still nothing.
    no lights come on on my dash or anything when i put the key in the on position..
    i dont have the fuse cover either, anyone got a link or anything to a picture of the fuse
    cover so i know which fuses are what?
