  1. KhmerSydeRide
    KhmerSydeRide Junior Member
    My accessorie wire doesn't work, I have to run my headunit directly from battery source... Anyone know why my accessorie wire doesn't work? I check fuse, tested with a meter but no power is coming from accessorie wire.. I know how to intsall radio but for some reason this 93 civic seems like the accessorie wire is dead... I turn my headunit on with a kill switch now but im tired of doing it.. any suggestion?
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    did you test it with the car on?
    what about pulling power right from the back of the switcgh?
  3. lowassaccord
    lowassaccord Senior Member
    You have a chance of having multiple fuses that control radio check all fuses that have to do with radio cig lighter and accys, actually check all fuses. should be fuse panel under dash and under hood one fuse in each for radio.
    if that doesnt work you can get an accy wire from above your fuse box in a brown connector its a large gauge yellow wire or from the ignition wire which is a black wire with a yellow stripe same location. P.S. always test wires with a multimeter before using to make sure you have to proper wire and always use inline fuse with the proper fuse size should tell you in install book of cd player.
    need anything else let me know.
    Kyle
