Carbon Fiber Hood Tsudo rock chips
Discussion in 'Body / Exterior / Interior / Cosmetics' started by HONDAPITSTOP, Feb 22, 2004.
  1. HONDAPITSTOP
    HONDAPITSTOP Senior Member
    I bought a TSUDO CF hood about 4 months ago and noticed lately how many chips are developing on the front of the hood. Does anyone with a CF hood experience this? If so what kind of hood do you have and how long did it take in months until you first started getting chips on the front?
    Here's some pics of my hood if you want to look at the rock chip damage.
    TSUDO CF Hood with chip damage
    Bruce
  2. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    Find out from the manufacturer what kind of resin matrix was used in the construction of the hood ( epoxie .etc ). Get some and fill the chips. Once cured, sand, buff and buy some of that 3M clear rock guard film to prevent a reoccurance.
    Good Luck
    Sean
  3. HONDAPITSTOP
    Thanks I'll check into that. Also you read my mind about wondering if there was some way of protecting the front part without looking too bad. Thanks again.
    Also, I'd like to hear from other CF hood owners if they've experienced this kind of rock damage within 4 months of driving with the new hood. I'm just curious what brands hold up the best from people's experience.
    Bruce
  4. BigJ
    I had a vis for a year, and had minimal if any, rock damage before I hit someone.
    Even when I hit the lady, the hood didn't do shit, the pins snapped, and it went straight up,, the corner chipped off, and I tossed it for a 50 dollar metal hood.
    I only paid 300 too. I wish I still had it. :(.
  5. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    Bruce, the Canuck told you what you can do to prevent it from chipping again- That film that 3M sells is pretty hard to notice and does a pretty good job of protected the paint or in you case CF-
  6. HONDAPITSTOP
    Sounds good thanks for the info :)
    Also, is the 3M protectant a spray or film that you stick on?
    Any application tips on how to apply it?
    Also, anyone know of a good place to get it?
    Bruce
  7. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    Check with your local body shop, they should have clear stone gaurd material you could apply, but I would personally try the epoxy/wetsand/buff method.
  8. Iquark
    Iquark Senior Member
    Mount Vernon, WA
    The 3m stuff is a solid plastic like thing. It's clear, and really hard to notice. As far as putting it on, the only way I've seen it done is through a dealer or bodyshop.
    Ian
  9. HONDAPITSTOP
    thanks I'll check out a local body shop and see how much they want to apply the 3m protector.
    Bruce
  10. jdm_civic_sirII
    jdm_civic_sirII Member
    would this work for bigger gashes? My hood flew up on me and smacked the windshield of my car. There are a couple of big gashes and the corners are damaged. sorry to jack the theard. Also the gashes didnt damage the CF just the top layer of the hood.
