cel 16...
Discussion in 'HYBRID -> ED-EF / DA' started by blk91b18, Apr 15, 2010.
  1. blk91b18
    blk91b18 New Member
    midwest ryda
    had ls swap in my ef sedan for 8 months now running great, and now sometimes when I'm driving through town I get a fuel injector code. Doesn't do it all when I'm on the interstate or racing it. Wtf!?
  2. skellagher
    skellagher Elder Driver
    Newark, De
    is it dual point or mpfi?
  3. skellagher
    Newark, De
    o wait didnt realize u had an ls well what i can say is replace the injector that the code is referring to if that doesnt work check the wire that leads from the injector to the ecu...
  4. blk91b18
    blk91b18 New Member
    midwest ryda
    how do i know which one its pointing to?
  5. skellagher
    Newark, De
    is it obd 0 or obd 1
  6. blk91b18
    blk91b18 New Member
    midwest ryda
    obd0 with 90pr4 and a resister box
  7. skellagher
    Newark, De
    well if you did the wiring for ur multi point check it... otherwise one of your injectors is bad and you can find out whick one it is by testing them with a multimeter set on i think 20 ohms and the injector with no reading is the bad one... are u sure u have the right injectors in it? they may be injectors that do not need a resistor box so if this is the case u will have to change them all.
  8. blk91b18
    blk91b18 New Member
    midwest ryda
    both the injectors and the resistor box are from a '91 ex civic. i will have to find my multimeter. lost in storage lol...
  9. skellagher
    Newark, De
    i know nissan is not related but i was throwing the same code in my 240 a couple years ago and it was just a bad injector. is ur car running choppy at all when the cel is on?
  10. blk91b18
    blk91b18 New Member
    midwest ryda
    performance is not affected. still pulls hard through third gear. no misfire or anything....
  11. DA16killer
    DA16killer New Member
    PA
    i would check ur wiring. i had a shaddy swap in my DA until i fixed stuff and lots of stupid shit would happen cause of faulty wiring. check your wiring and make sure you dont have an unwanted ground or something hiding out somewhere. if not then just replace the injector.
  12. skellagher
    Newark, De
    thats what i am thinking ...
  13. blk91b18
    blk91b18 New Member
    midwest ryda
    thanks for the input will do this weekend-still cant find my multimeter?!
