Center console fitment
92CHB
I have a 92 hatchback and i was wondering if a center console from a 4dr will fit in my car. The main reason i want it is for the armrest. Will that fit fine around my e-brake and fit in between the seats or does it take alot of modification to make it work? Thanks guys!
It should fit with little or no modification...I'm not for 100% sure, but if it doesn't bolt right up, it shouldn't be much to make it fit.
it should bolt up the same way, I not 100 surebut even if you have to mod it a bit no biggie. I put a arm rest from a integra into my crx and only had to redrill new holes.
It will fit just fine if the console is from a 5th generation four door.
