Changing Tranny Gears?
mrcheesehead
Hey Guys I own a 87' Honda CRX Si that I do some circle track racing with. My car has the tendency to hit the rev
limiter at the end of the strait away. My question is how easy would it be to get longer gears for it so it does not hit the rev
limiter? What car do I get the gearing from? Do I need a different trany? I do not care to go to a larger tire to change
gearing on the track.
Thanks guys
Aaron
the Ew4 motor really isn't compatible with any other's that i know of. I'm not sure if a ZC or another 88+ si tranny would bolt up to it. you'd have to do some research on that.
if i were you, id go to the larger tire. what are you running now?
