changing vtec engagement
Discussion in 'General Tech and Maintenance' started by sniezek66, Apr 3, 2004.
  1. sniezek66
    sniezek66 Member
    thansk to all who answered my question, but i have one more. I bought a p72 ecu that was reprogrammed and he aske dme what i want my vtec engagement to be set at. Right now he has it set at 5,500rpm. Would i be better off to have it set back to 4,400rpm or what should i tell him. Just curious to at what rpm ratign i will get the most performance out of the vtec
  2. BseriesKllR
    BseriesKllR Senior Member
    well whats your setup???
  3. E_SolSi
    oh boy
    if its a chipped ECU then i would be willing to bet that the fuel maps have been fucked with and such as well as the VTEC engagement
    i would probly pass on that ECU and try to get a regular non-molested one
  4. sniezek66
    sniezek66 Member
    well here is the link to it check it out yourselves http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEBWA%3AIT
    I was also alittle concerned that things may be altered in there so you think i should just stay with a stock ECU??
    My setup on the motor is all the bottom end internals have been changed over to type r. It has the b18c1 blcok with a b16a head that is port and polished. The cams valves ect are all type r too the whole motor is basically type just has the gsr block and b16 head.
  5. sniezek66
    sniezek66 Member
    also i forgot is there a big difference between the jdm ecu and the usdm ecu or does it not make much of a difference whcih one i get
  6. pissedoffsol
    wihtout a clutch switch, launch control is useless. i'd pass on that like airj0ckey passes gas
  7. uptowng2ic
    uptowng2ic Member
    NY
    the JDM ecu tops out sooner than the USDM ecu.
  8. E_SolSi
    yup the JDM ECUs are speed limited at 180 KMH (about 112 MPH)
  9. sniezek66
    sniezek66 Member
    so i should stick with the USDM ECU then.
  10. E_SolSi
  11. E_SolSi
    or get an EDM one
    more agressive fuel maps, no speed limiters
    EDM 0wnZ j00!!!1!
  12. sniezek66
    sniezek66 Member
    Thanks E Solsi you've been a big help. One other thing since i have to get a adaptor harness from obd0 to obd1 for my 91 hatch do you know what is the best company to get one from and does this make wiring up the vtec compenents alot easier. That's my only worry right know is getting the Vtec wired up correctly since i have everything else already wired up. Let me know
    Thanks Again
  13. E_SolSi
    not too sure about pre 92 cars
  14. UDT
    UDT Senior Member
    california
    Veeeeeeeeeeeeeeery intersing...........
    <......lights a match
  15. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    wtf...........oh well..
    like E said
