cheap gsr block and misc b series
Discussion in 'Parts: For Sale/Trade/Wanted' started by SoSlo, Aug 25, 2005.
  1. SoSlo
    SoSlo Member
    nor cal
    stuff for sale:
    B18C1 block with mains and gurdel $125
    B18C1 crank (needs to be micropolished on one jurnal) $75
    p72 un tapped oil pan make offer
    p72 water pump(used) $20
    obd2 crank angle sensor $25
    gsr head bolts $25
    arp gsr rod bolts (new in package) $50
    b16 rods $20
    gsr throttle cable $10
    jdm gsr injectors obd1 $25
    2x gsr crank pulley $15
    misc 2.5 inch steel tubing make offer
    turbo 5 bolt flange $15
    blue steering wheel with air bag $40
    driver side manual eg mirror $10
    2x 2.5"-3" coupler $10
    3" t-bolt clamp $3
    vx front spindles with brakes and rotors $10
    vx rear drums with e-brake cables and arms $10
    vx brake master cylinder $5
    everything is OBO
    if interested hit me up at smmccurdy@hotmail.com
    lacated in washington
    things i really need
    low comp pistons for a gsr
    aftermarket rods for a gsr
    aftermarket radiator for a 92-92 civic
  2. brian11to1
    brian11to1 Senior Member
    how much for the gsr block, crank, pan windage tray oil pick... etc... 85323
  3. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    Damn Bri... I think you just got lucky,.... ;) Just what you were looking for....
  4. SoSlo
    SoSlo Member
    nor cal
    i dont have the oil pickup but i will send you this
    gsr head bolts $25
    for $200 plus shipping
    i will check on shipping tommorow morning and let you know
    i need it gone by sep 7 since the army is moving me and i dont have the room for it
    i have paypal
    slohybrid is my ebay name for vouches
  5. brian11to1
    Ok, sounds good. Are the head bolts used? If they are, are they any good? I really need that pick up... does the block come with the oil pump, front and rear main seals? What does it not come with?
  6. SoSlo
    SoSlo Member
    nor cal
    the head bolts are used but still look to be good
    ill even throw in the stock injectors
    here are are some pics
  7. brian11to1
    Find out shipping and Ill figure out if I'm going to use it. And what exactly are you including with the deal. Also, I dont need a lot of parts sitting around.
    So, in reality Im not going to need the headbolts or injectors.
    I will take: Block, Crank, Girdle, Pans, Front and Rear Mains, Main, Water necks, Water tube (goes from water pump, to thermo housing), timing belt covers (if you have them) Let me know what you've got exactly
  8. brian11to1
    and get GOOD pictures of the cylinder walls. Why is it taken apart...
  9. SoSlo
    SoSlo Member
    nor cal
    it is apart cause that is how i recieved it. i dont have the oil pan or the front seal or the belt covers. i am including everything in the photos
  10. brian11to1
    Alright, well as soon as I get a response on 2 others, I'll let you know. That's too many more parts I would need to buy.
  11. B18HondaEg
    B18HondaEg Member
    intersted in block, oil pan. shipped to 02719 MA. where u located???
    hit me up on AIM...B18 Honda EG
    crank pulley and 5 bolt flange too
  12. adidas_man
    adidas_man Honorary Honda Driver
    Warrensburg, MO
    did you check the last date that someone posted here Aug 26, 05
  13. GSRCRXsi
    MD
    if brian passes the block up, how much do you want for just the windage tray and the thermostat housing?
  14. freddycivic
    freddycivic Member
    Saint John, New Brunswick
  15. B18HondaEg
    B18HondaEg Member
    haha nah man thanks.
