Chech Engine Light From O2 Sensor?
Discussion in 'ECU's, Electronics, and Tuning' started by edwardsirignano, Mar 1, 2003.
  1. edwardsirignano
    edwardsirignano Junior Member
    I've just put headers and a exhaust system on my 1997 Honda Civic. The headers came with only 1 spot for a o2 sensor. The car has 2.
    [1] Is the second o2 "really needed"?
    [2] How can I bypass it to turn the damn check engine light off?
    Thanks
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    OBD II cars run two o2's and their ECU's look for them.As far as how to get rid of the CEL there are a couple of ways,run a chipped ECU that doesn't care and I've seen these things you can plug into the second o2's plug instead of the sensor and it tricks the ECU,but I don't know if they are availible in import applications.Someone else may know a better way.
  3. SixtySecondAssassin
    Austin, TX
    you can splice the wires from the second sensor into the first. your car might run rich or lean.
