HellBentHONDA
ok. my check engine light comes on :
1) after the car has warmed up
2) above approx 38mph - give or take a few mph's
3) only with some throttle pressure - but not WOT or too little throttle
the light will reset when the key is switched off and no code will be stored. im thinking its a bad ground or something simple. this has been going on since i did the swap and i'd like to fix this before installing my turbo.
car : 93 cx hatch
ecu : p72
also on a side note im curious about the knock sensor. ive always assumed it was connected to my ecu but never checked as vtec is the only thing people say you need to wire with this swap. thanks for any and all the help
car : 93 cx hatch
ecu : p72
