Chipped VX ecu (P07)
Discussion in 'ECU's, Electronics, and Tuning' started by eghatchvtec, Mar 19, 2004.
  1. eghatchvtec
    eghatchvtec Junior Member
    Does anyone know if you can chip a P07 ecu from a civic VX? It's a VTEC ecu, will it work?
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    There are 3 different flavors of the P07 ecu, I can't remember off the top of my head, but ONLY 1 can be chipped/socketed/programmed to work like a P28.
    I've come across many P07's, but never found the right one.
  3. eghatchvtec
    I got my answer, you can if you have a certain one. If the circuit board reads - 02D011F0-1500 or 02D01720-1500 at top then you can. If its a 02D01560-1500 then your outta luck.
