Chips for P28
Discussion in 'ECU's, Electronics, and Tuning' started by calvin, Oct 9, 2002.
  1. Motor ECU VTEC REVL MAKER
    88.9%
  2. D16Z6 P28 5100 8500 XS
    11.1%
  3. D16Z6 P28 5100 8130 RPT
    0 vote(s)
    0.0%
  4. D16Z6 P28 5000 9900 RPT (with greddy turbo kit 8psi)
    0 vote(s)
    0.0%
  5. D15B P28 5100 8000 RPT
    0 vote(s)
    0.0%
  6. D15B P28 5100 8500 SPOON|
    0 vote(s)
    0.0%
  1. calvin
    calvin Senior Member
    NETHERLANDS
    These are from racingchips.com
    They are ecu clones.
    Witch one is the best do you tink???
    I will be using it in a p28 for my mini-me setup.
    THANKS
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    just get a p28 ecu
  3. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Get the GREDDY KIT and BOOST that shizzy yo!
  4. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Calvin-
    Let me tell you what I do know about the P28 chips.
    If you are using a JDM P28, then the chips listed for D15B will work fine, but if you are using a USDM P28, they will not, unfortunately.
    So that limits your choices quite a bit.
    Oh, I also saw your other thread on soldering the ecu board, and all the stock chips are soldered directly to the board. There is no factory honda ecu that I know of that comes socketed. So you will have to solder any ECU you get, unless someone has already done it.
    Now, on to your chip choices.
    What else have you done to the engine, besides putting in the VTEC head. Also, are you using the 1.5 block or 1.6 block?
    You don't really want to raise the redline, unless the engine can take it, otherwise, you may do some damage.
    If you want to chat some more about this, PM me. I'll be glad to help you out with your choices.
  5. pissedoffsol
    just run a regular P28. no chip needed.
    get a vtec controller or hondata instead if you want, but again not necessary.
  6. pills_PMD
    New Albany, OH
    like i said.. just get a p28
  7. bte15
    bte15 Senior Member
    Bellevue, Washington
    hondata mmmmmmmmmm my next addition
