Choice of cams?
Discussion in 'Integra' started by makemagick, Feb 20, 2013.
  1. makemagick
    makemagick Member
    Sooo at the end of spring i want to do my head.
    I've decided to go with super-tech internals (maybe stock retainers)
    (However if you have a better suggestion go ahead suggest)
    AEM or Golden Eagle cam gears
    3 angle valve-job
    and im stuck choosing cams...
    Originally I wanted skunk2 stage 1 or 2, but from quite a bit of people heard they are not good, however i also heard alot of good stuff about them
    another choice is BC but seen quite a few broken pictures of Brian Crower cams
    Web - never heard of them that much, but a few people suggested that
    Comp cams - i know 1 person who runs it, internet community tends to "stay away" from ebay cams.
    What im lookin for is 200 h/p +- 5 hp with a built head with a later possibily of turboing.
  2. E_SolSi
    what engine?
    any bottom end work?
    how will you be tuning it?
    what other parts (i/h/e/etc)?
  3. makemagick
    makemagick Member
    jdm b18c
    10.6 compression stock bottom end
    you mean with what program or what chip?
    crome i suppose, chip? im pretty sure p28
    for now im just thinking bout the head n how much i can get with it alone (after the tune obviously)
    Right now i have skunk2 im with b16 throttle which im gonna replace with a bigger throttle like 68 inches
    I do have headers im not sure which ones though they are not stock but i have not found any visible indicators
    And im getting my exhaust done soon, i'm thinkin 2'5 2'75 (i do not want 3" as in im not gonna have that much power eveeen if i get a turbo later)
  4. hickskateboarder
    hickskateboarder New Member
    2 layer head gasket and flat faced valves to bump compression up will help. u could also take a crack at gasket matching the head, header, and IM.
  5. SlushboxTeggy
    NJ to MA to CA
    You mean 68 MM.
  6. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    I have had good luck with Blox cams, and know a couple other people with them.. no probs.
  7. reikoshea
    Dallas, TX
    Wonder why people say stay away from comp cams. They're not an ebay company, but they're definitely not known for their import performance work. Doesn't mean they're bad, they're a go to vendor for domestic v8s.
