chrysler ME 4 12
posol
RETIRED
bad fucking ass.
had a speco in the new car and driver this week....
mid engine quad turbo V12.
850 hp.
1/4 in 10 flat
out performs the Enzo.
i want it.
and at 500,000.... its probably nto worth it.
http://www.allpar.com/cars/me412.html
The ME 4-12 is not a concept car but a prototype. According to Deutsche Press, around 300 Chrysler ME 4-12 will be built each year, largely with carbon, aluminum, and other light-weight metals. Road testing is scheduled for late January, with production rumored to start within two years. The car itself is being built in the United States by Metalcrafters, and we have been told that the lead engineer is from Chrysler and the lead suppliers from North America - and that this was the outcome of battles with Stuttgart, which wanted to use European suppliers and engineers. Most off the shelf parts appear to be from Chryslr aside from the engine. The transmission seems to be based on Chrysler, Mercedes, and other designs.
The ME stands for "mid-engined." The quad-turbo, V-12 powered Chrysler ME Four Twelve supercar may not only establish real-world performance records but may also set a record for lightning-quick vehicle development. It took less than one year to complete from start to finish (though we don't know what they started with).
The engine is from AMG, with 850 bhp @ 5750 rpm, with 850 lb-ft. (1150 N-m) of torque between 2500 and 4500 rpm on premium unleaded fuel. It was reportedly designed for Chrysler, but will probably be used by Mercedes in other applications (we'd expect it to appear in the Vision and perhaps the McLaren SLR). Use of the AMG engine was dictated largely by the need for high power with light weight (around 500 lb) and at reasonable development cost.
With a curb weight of just 2880 lbs. (1310 kg), the ME Four-Twelve has the weight-to-power ratio of 3.4 lbs/bhp – a new performance record. In Chrysler projections and modeling, the ME Four-Twelve goes from 0-60 mph in 2.9 seconds, 0-100 mph in 6.2 seconds, and it will blister through the quarter mile in 10.6 seconds at 142.0 mph. The estimated top speed of the ME Four-Twelve is 248 mph (400 km/h). The vehicle is designed and packaged to achieve outstanding thermal performance under extreme operating conditions. Its large capacity, high-efficiency engine-cooling system allows this engine to retain optimum thermal performance – a key advantage in the super car arena.
The 7-speed Ricardo Double Clutch Transmission was developed specifically for this vehicle and features the latest double wet-clutch technology and electronic control strategy. The exclusive transmission delivers uninterrupted torque to the rear wheels with 200 millisecond shift times. The double wet-clutch technology appears to come from Chrysler.
The ME Four-Twelve's carbon fiber bodywork was designed to mate to a carbon fiber and aluminum honeycomb monocoque tub. Aluminum crush structures and chrome-moly sub-frames complete the ME Four-Twelve's rigid support structure, which complies with US federal impact regulations.
The suspension is comprised of double wishbones, aluminum control arms, horizontally-opposed coil-over dampers with electronically controlled compression and rebound tuning, stainless-steel push rods and a blade configured anti-roll bar. The power-assisted rack-and-pinion steering has an overall ratio of 16:1 with 2.4 turns lock-to-lock and a turning circle of 36.0 feet.
The ME Four-Twelve braking system features massive 15.0-inch (381 mm) ventilated carbon ceramic composite disc brake rotors with six-piston aluminum mono block calipers for superior braking performance during all driving conditions. The composite discs are sixty-five percent lower in weight than comparable cast iron rotors. Wheels are cast aluminum: 19x10-inch front and 20x12.5-inch rear. Michelin high-performance radials are 265/35ZR19 in the front and 335/30ZR20 in the rear.
At just 44.9 inches tall, 78.7 inches wide and 178.8-inches long, the two-seat, mid-engine ME Four-Twelve was wind tunnel tested in Auburn Hills. The computer controlled active rear spoiler articulates rearward 100 mm to increase down-force to a total of 925 lbs. (421 kg) at 186 mph (300 km/h), while achieving a competitive coefficient of drag (Cd) of 0.358. All body openings have been optimized to achieve maximum thermal performance. Large vented front and rear wheel houses reduce lift as well as active and passive aerodynamic devices that have been implemented to provide stable vehicle performance at all speeds.
The interior is relatively spacious with 37.2 in (942 mm) of headroom, and 42.7 in (1085 mm) of legroom. A large glass roof panel extends from the windshield to the rear header. Passenger-side adjustable foot support helps keep the co-pilot in position during extreme cornering maneuvers
This vehicle breaks the mold of the super car genre because its packaging can easily accommodate drivers in a wide range of heights. Ease of access to driving controls was a primary focus. For example, there are steering wheel mounted controls, including a column mounted F-1 racing style paddle shifter with aluminum shift paddles and centrally mounted driver controls.
Wolfgang Bernhard, Chief Operating Officer - Chrysler Group, said, "It's everything we’ve learned about creating exciting, desirable automobiles. And, as such, it's not really a concept car but is, in fact, a prototype that will be road-ready by summer."
"Wheatking" noted:
The SLR McLaren is the top of the Mercedes [sport] line.. they've spent millions on it.. and they've spent years on it.. it represents the best of anything Mercedes.
Enter the ME-412.. they took a Mercedes engine.. took it to Mercedes tuner... they spent a year.. and outdid the SLR McLaren..
Chrysler can do in 12 months what it takes Mercedes years.. and not only can it do that, it can do that with their parts for less and better to boot!
AMG Powertrain and Ricardo Clutch Transmission for Unmatched 0-60
Performance
The heart of the ME Four-Twelve is its all-aluminum, quad-turbo, 6.0-liter V-12 engine. With electronic sequential multipoint fuel injection and a 9.0:1 compression ratio, the ME Four-Twelve's AMG-developed engine delivers 850 bhp @ 5750 rpm, with 850 lb-ft. (1150 N-m) of torque between 2500 and 4500 rpm on premium unleaded fuel. The specific power output translates to 142 bhp/liter, and with a curb weight of just 2880 lbs. (1310 kg), the ME Four-Twelve has the weight-to-power ratio of 3.4 lbs/bhp -- each of these sets new performance records and new benchmarks in the super car category.
And, befitting a machine that will play comfortably in the super car league, the performance of the ME Four-Twelve is stunning. In our projections and modeling, the ME Four-Twelve goes from 0-60 mph in 2.9 seconds, 0-100 mph in 6.2 seconds and it will blister through the quarter mile in 10.6 seconds at 142.0 mph. The estimated top speed of the ME Four-Twelve is 248 mph (400 km/h). The vehicle is designed and packaged to achieve outstanding thermal performance under extreme operating conditions. Its large capacity, high- efficiency engine-cooling system allows this engine to retain optimum thermal performance -- a key advantage in the super car arena.
The 7-speed Ricardo Double Clutch Transmission was developed specifically for this vehicle and features the latest double wet-clutch technology and electronic control strategy. The exclusive ME Four-Twelve transmission delivers uninterrupted torque to the rear wheels with 200 millisecond shift times.
Advanced Composite Structure, Cat-Quick Agility
The ME Four-Twelve's advanced, carbon fiber bodywork was designed to mate to a carbon fiber and aluminum honeycomb monocoque tub. Aluminum crush structures and chrome-moly sub-frames complete the ME Four-Twelve's rigid support structure. Taking advantage of its impressive racecar-like structural rigidity, the ME Four-Twelve's suspension, steering and brakes are engineered for super car performance. Overall, the vehicle's structure -- consisting of multiple materials -- achieves an ultra lightweight design with outstanding vehicle rigidity and complies with all US federal regulations related to impact testing.
I have seen it in person (detroit autoshow), and was not impressed. It looks just plain ugly, and I really doubt that DC will every produce it with the HP figures that it has now.
kinda reminds me of a Ford GT90... kinda...
I seen it too, however I was impressed with it. it looks badass, but alas I will never be able to afford it.
2 pics i took of it at Detroit Auto Show:
rear:
front:
i dont like all those all LEDs for the tail lights...but other than that it was badass looking. as you can tell there was alot of people looking at it.
I hate how all of chryslers cars have the ghey lines in the hood. Maybe that is what I dont like about it (and the rear end)
