No, you're wrong. If you had one you would know that it has a 1.7 SOHC VTEC. Not the DOHC. The 1.7 DOHC VTEC was in the 90-90 GSR. The hp is correct though, 127.
all USDM Civics come/came with a SOHC motor except the 99-00 Si and 02-03 Si.
just in case someone tries to be a jackass and get technical, there is one exception to this rule. the early model Del Sols were called Civic Del Sol, still part of the Civic family, and the VTEC models had a DOHC motor.
