Civic Engine Swap
sweetride
To put a 98 integra engine into a 93 civic do i use the ecu that came with the 98 integra engine or do i need one that is OBD1?
you will need an OBD-1 ECU
you can modify your harness to work
what model civic do you have
and what 98 integra engine
It is a cx civic and a b18b integra engine, how do u modify the harness ?
swap the injector plugs
swap the distributor plug
swap the alternator plug
lengthen a few wires
or if its a USDM engine and you have the harness use that it will plug into your harness at the shock towers
