Civic motor swap to b18a1
Discussion in 'HYBRID -> ED-EF / DA' started by Carnage, Sep 21, 2003.
  1. Carnage
    Carnage Junior Member
    I have a complete 92 teg parts car, and I want to swap the teg's B18a1, in my 90 DX.
    I know I need a motor mount kit , for b series engines,
    I'm just wondering if I can use the teg's axles, shift linkage, ecu, pretty much just swap the for end of the car ?
  2. brian11to1
    brian11to1 Senior Member
    First off you must convert from DPFI (dual point injection) to MPFI (multi point). You can't use the ECU, it's OBD-1 you are OBD-0... so you have to get a different PR4 ECU from a 90-91 RS-LS-GS Integra (I have one [pm me and we can talk about a price], and a Engine Wiring harness from this car as well (I may be able to get this too!). Then again you can always convert from OBD-0 to OBD-1 it's a hard core thing to do... there are threads nad websites (listed below) on converting OBD's though. Shift linkages you will have to have someone change those, change I mean cut and shorten them I believe.... there are articles on this, go to HASport and see what they got they make all kinds of moutns and shit, they even have shift linkages for B series swaps into a your car....
    Threads concerning DP to MP Conversion
    Or even this one
    Here's a site that gives a How To change OBD's
    Hope i helped man, later and good luck
    and use the search button not everyone will look this up for as I have just done.
