Civic Wagon 4WD
Discussion in 'HYBRID -> ED-EF / DA' started by psi, Feb 8, 2007.
  1. psi
    psi Junior Member
    I saw a Civic Wagon on sale today and it is a '88. I am asking if there is any history of a B series swap done to this particular car before buying it. I am pretty sure any D series engine will fit. And if a B series swap is possible, will there be complication with the AWD system and the B series tranny/engine.
  2. tunedhonda-ata
    tunedhonda-ata im turbo bitch!!!!
    D-town
    man that would be nice to do an 89 ls integra swap into it..it will bolt up to the single cam tranny.. then turbo that thing..
  3. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Yeah, I agree, I think it would be easier to stick to D series. A built/turbo'ed D16 AWD would be pretty cool!
  4. tunedhonda-ata
    D-town
    yeah the old 89 integras are d-series and dual cam, it should also plug into the wire harness
    well atleast i think it is the 89.. what ever year has pop up headlights
  5. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    The D16A1's will NOT be a direct bolt in swap. The driver side mount is completely different. You'd be better off going with a DOHC ZC. I've been thinking about building one of these for a while now but I can't find a good FWD one near me. I want FWD because i want to do a B Series swap and I don't know if you can run the AWD wagons with just the rear drive shaft disconnected.
  6. phunky.buddha
    Dallas / Fort Worth, TX
    You can shove a B engine in there with a B to D adapter. Better yet, try an H.
  7. psi
    psi Junior Member
    So, I'm guessing a ZC set up is the easiest with a turbo. Now my question is what is the difficulty level in doing this conversion/swap?
  8. tunedhonda-ata
    D-town
    not to sure but the dohc ZC should bolt to the tranny in the car
  9. psi
    psi Junior Member
    Okay for the earlier posts, H series is just way too complicated. Its too much work for the power gain. B series is more cost effective but still requires a lot of work. Now the ZC, from what I am now getting is the most bang for the buck. Or I could just swap it with a electric engine so I can have a 0-60 in 3.5 sec. But then the cost of a electric car is like what? Somewhere in the $12k range.
  10. eg6sir
    that AWD wont hold up to much power though
  11. phunky.buddha
    It's not too bad if you use the stock drivetrain with the stock D transmission.
  12. psi
    psi Junior Member
    Why won't the AWD hold up to the power boost? Isn't there like a upgrade for the drive train to support the higher HP?
  13. psi
    psi Junior Member
    Is it because the parts are "old" and that its a '88? Anyways, I have not bought that civic yet and the individual was "pressuring" me to make the purchase on the spot. I do not like to be pressure and all that. Especially when I am going to spend more than $1k to buy it. But thanks for the input on the upgrade options for such a old car.
  14. phunky.buddha
    If you're being pressured to buy the car and you're not comfortable, always pass on it. Don't be bullied into a purchase that you're not sure you're going to be happy about.
    As far as transmission strength- I don't know personally, but most believe that the old wagon AWD systems just weren't designed to handle much power, and that the torque split to the rear was only 10%.
  15. psi
    psi Junior Member
    That is why I never called the guy back. I dislike being pressured to get something that is a big dollar item. And why is it 10% rear?? That is so lame. I thought it was like closer to 50/50 or something like it.
  16. phunky.buddha
    Like I said, I'm not sure- I've never seen anything official about it. That's just the accepted number that everyone goes by, and I'm sure there's quite a bit of proof saying that the rear only gets 10%- I've just never seen it.
    10% to the rear would be enough to make sure that the car maintains traction in some slippery areas.
  17. psi
    psi Junior Member
    Well, "if" that is the % to the rear, then its not as great as I initially thought. I guess I'll have to do a bit more research to see how much is actually put to the rear.
  18. phunky.buddha
  19. terror_si
    terror_si Junior Member
    b series
    go b16 with crv manual trans crv rear custom drive shaft
  20. richie_
    richie_ New Member
    heeha!but is that possible?i´ve read that the cr-v manual trans perhaps fit to the awd but would it fit to an b16, or b18 and not only to the b20b3 which is in the cr-v?i have the same problem, not with the awd wogavan, but with the awd sedan ( ee5 ).
