Cltuch Pedal Adjustment
Discussion in 'General Tech and Maintenance' started by cyphen, Dec 18, 2002.
  1. cyphen
    cyphen Member
    self explanatory question....i want to adjust the pedal height on the clutch pedal...is that possible and if so how...cant find the fucken book anywhere here.... :(
  2. farmer_jason
    farmer_jason Senior Member
    florida
    do u want to adjust where the clutch releases or the hight of the pedal
  3. D See 2
    D See 2 Senior Member
    Baltimore, MD
    i know there is if its a cable tranny, i just adjusted mine last week. There is a threaded cap on the clutch bracket that mounts to the tranny. good luck!
  4. pissedoffsol
    the problem with adjusting it is that it will fuck with your clutch.
    too high, and it won't hold
    too low, and you will grind every gear because it doesn't release all the way.
    thats what the adjustment is there for- to get the sweet spot of grabbing and not grinding, not because you are a lzy ass and don't want to move the pedal the whoel distance :p
