clutch and axles from a 89dx work in a cable Si tranny?
Discussion in 'HYBRID -> ED-EF / DA' started by mesa50w, Dec 26, 2008.
  1. mesa50w
    mesa50w New Member
    I picked up a 89 dx HB about 2 months ago to be a daliy driver so the STi can get a cage in it for trackdays. the motor that came in it started smoking pretty bad so I thought what a perfect time to do a d16z6 obdI swap with a si tranny-_-. The clutch and axles that are in the car now are only a month old. Can i use them on the Si tranny? I was told the Si tranny is out of a 90 si. thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yea that stock si tranny will bolt right to the new motor no problem
  3. mesa50w
    mesa50w New Member
    thanks thats what i thought
  4. mesa50w
    mesa50w New Member
    update
    olmost done just need to find where some vac lines go and finish installing the harness.
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    vacuum lines,rlly just put them anywhere
  6. mesa50w
    mesa50w New Member
    Yea i feel kinda dump but its the hose for the throttlebody ( one on top and one on bottom), fast idle thermo, IAC valve thats giving me a hard time.
    My z6 dind"nt have a throttlebody or any of the sensors on the mani when i got it so this is my first time seeing it. I have the manual for a del sol so all the Z6 info is in there but i just cant seem to find how to route those hoses.
    also the sensor under the Dizzy( looks like a coolant temp sensor to me) but i thought the coolant temp sensor was over by the heater hoses??
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    the hose on top(i believe) goes to the charcoal canister,and on the bottom,i believe flows coolant
  8. mesa50w
    mesa50w New Member
