clutch cable help
Moses154
Hello all i need some info asap plz
I have a 1990 Crx si with a b16a jdm with cable ls trany (Acura integra trany)
the clutch cable broke so i need to know if i need a crx clutch cable or a acura integra clutch cable please help
also if there is some kind of wiring manual on the web for a b16a jdm because i have some lose wires
the si cable should work. they are routed different but the si cable should work just fine. the swap trans is a cable tranny right.
the si cable broke i still have the cable from the ls tranny that was on it when i picked it up but i was told it would not fit to the crx due to slack but i dont know if that is true.. so what im asking is will the ls tranny cable that came with the trany fit to the crx no problem or well i have to find a si cable
It should work. I'm assuming its a 90-93 LS, correct? The engine bay on the DA's are similar to the EF.
it wont hurt and wont cost anything to try it. just a little time.;)
