ok, here's something interesting. When i did my swap, i noticed that the cluth on the new trans was a little stiff, and hard to push down. Well, over the couse of a few months it got a little harder and harder to push. Now all of a sudden, the pedal won't go down at all. I tried bleeding the system to check if it was the master cylinder or the peddle, but those worked fine. My guess was that my throw-out bering has seized on the input shaft.(which would explain on why it was so hard on the get-go.) So, my plan is to pull the trans this weekend and do the whole thing: clutch, pressure plate and berring. Before i start, does anyone have any suggestions on what else could be causing this? The settup is a B18 from a 95 GSR being used in a 93 del-sol.
Thankx!
Thankx!
