if you read my other post titled "engine code 6" then you know that i put everything back together yesterday.
the other problem i'm experiencing is that the clutch pedal has nop pressure behind it. what i mean is, as soon as you press the clutch pedal in the damn thing goes straight to the floor and it doesn't come back up. i tried pumping it a bunch times but no luck. i checked the fluid, it looked ok. i even went as far as bleeding the clutch master cylinder but i still don't get any pressure in the pedal.
the pedal doesn't even come up at all. you have to pull it up yourself.
if worse comes to worse i'm going to replace the cluth master cylinder.
ANY SUGGESTIONS???
ANY SUGGESTIONS???
