clutch problems
Rattler66
what are the symptoms of a bad clutch/pressure plate? etc... i have such bad clatter when releasing the clutch, i thought it was wheel hop, i replaced any bad mounts (all are new now). so i'm thinking the clutch assy is bad. also you can really feel the gear shift knocking around when it happens. thanks
thanks........i guess the whole kit and flywheel's getting done.......then shocks and finish bodywork. almost there.
