Clutch problems
Discussion in 'HYBRID -> EG-EK / DC' started by GmodKid, Jun 6, 2012.
  1. GmodKid
    GmodKid New Member
    I have an ls motor which I just put a stage 4 clutch kit on with pressure plate and new pilot and throw out bearings. My clutch isn't engaging properly or fully so I was told that I need a longer slave cylinder. If so what slave can I use? Would it have to be after market? Can I use an h22 slave? Help me please
  2. GmodKid
    GmodKid New Member
    No one?:(
  3. Jared759
    Jared759 Well-Known Member VIP
    SC
    Bleed the clutch and also adjust the pedal to the proper specs. More than likely its never been adjusted which can cause premature clutch failure. If you have a haynes or chiltons manual it will tell you how to do it.
  4. serrilion
    serrilion In my own little world! VIP
    Vermont
    Also there is a clutch break in of 500 or so miles... also note that
