S sevenhillsbilly New Member Oct 7, 2008 #1 i have an 89 crx and i was wondring would a 90-91 clutch kit fit on the 89 flywheel or are the 88-89 comepletely differnt?
Matts96HB . Moderator VIP Oct 7, 2008 #2 As long as its the same series engine, you should be good to go. i.e. A d-series clutch will fit any d-series, but you can't go b>d-series. Thats what I've found so far.
S sevenhillsbilly New Member Oct 7, 2008 #3 well i knew that i was just wondering if the holes for the clutch were diff
Matts96HB . Moderator VIP Oct 7, 2008 #4 Umm, no. They should be the same. Might want to do some searching though, I'm not 100% on this one.
