So, I just bought a 97 dx manual, and when the clutch is in ALL the way, the car sounds great, when you let the clutch out even just a little bit, there is a grinding noise. Also when you drive it, there is a grinding noise when power is being applied, in any gear. My dad said that its not the TO because it would stop after just pushing the clutch in a little ways. Also, the clutch seems to work fine--I can drive it easily, there is just a terrible grinding noise. Any clues on what I should start changing? If not im gonna just start tearing the thing apart!!! I'll find out one way or another!!! Any help would be awesome
