Clutch
Discussion in 'General Tech and Maintenance' started by civic_types, Mar 26, 2004.
  1. civic_types
    civic_types Senior Member
    Shoppin' for a new clutch for my JDM B16a SIR2, with a Y21 LSD tranny
    What would you guys recommend?
    Act......... Centerforce Dual friction?
    I remind everyone, this is only a street car.... stock internals....... with add-ons and I may run a little bit of spray from time to time.
    Thanks in advance
  2. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    Clutch Specialties makes excellent clutches, I'll look for a phone #
    here's the website: Clutch Specialties
    their website aint much to look at but they make some of the best clutches I have ever seen. all my friends and I use their clutches.
  3. H22AdelSol
    H22AdelSol Senior Member
    san diego, california
    ACT w00t
    i think i got my xtreme pressure plate and stage 1 clutch for $450
    grabs pretty damn hard for my combo. I would say perfect for street.
  4. E_SolSi
    no such thing as "stage 1" or "stage anything" for that matter
    ACT doesnt use "stages"
    check for yourself
    but yes ACT clutches are badass
    i have the AI4-XTSS (extreme pressure plate and street strip organic disc)
    very good setup for street use :thumbsup:
    if you are a pussy and cant deal with a hard clutch pedal then go with the HD (heavy duty pressure plate) its not as stiff
  5. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    :concur: i had ACT in my prelude and will be running it again on my GSR motor in the hatch- :thumbsup: to ACT
  6. civic_types
    My local ACT dealer is a Fucktard. Askin' way too much , plus he tells me that he has to do the install to warranty it.......... Anyways.
    I have gotten a half decent price on a Centerforce Stage 2 clutch, any people ever have a problem with this particular setup?
  7. civic_types
    Well, I finally went with the Act HDSS Set-up
    -Heavy Duty Pressure plate
    -Street Disc
    -Release bearing
    -pilot bearing
    Got my Flywheel shaved, Torqued everything to spec, didn't let anyone else drive it and it has this horrible rattle. Only when taking off. Shifting is Perfect, driving is perfect, only taking off.
    Mind you guys that it is still is in break-in period. Is This Normal?????
  8. B18Civic95
    B18Civic95 Member
    Same here! Not in break in period though. I got about 15k on my clutch but aroun 1k-2k i hear a little rattle. Do you guys know what it might be?
  9. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Maybe one of the springs in the disc hub busted. HOw about throwout bearing failure?
