clutch?
91crx
what clutch and flywheel do i use if i am using the 0bd1 sohc zc motor with an 88-91 cable si tranny?
thanks
brett
thanks
brett
[post=393820]Quoted post[/post]​
bump
order the clutch for the transmission and the flywheel for the motor. make sure you figure out what year tranny is is though, since the 88 tranny has one less spline on the output shaft than the 89-91 models...easiest way to tell, count the splines on the tranny, 20 splines = tranny from 1988, 21 splines = 89-91.
