i swaped a ls motor in my crx dx and i never even got to fix that code 1 which i believe is a o2 sensor i ran it like that and now i have two more problems my speedo cable snapped ok i need a new one but a freakin injector wtf it ran good when igot it. its my daily driver so i need to do something fast to fix this problem how do i check for the bad injector or if its the connection also when im in the freeway and i go over 4k rpm the motor boghhhhhh and it will not go i thought this was my tranny going bad now i think its my ecu p74 obd1 there is also times where the check engine light goes of and ill get no codes and it will run fine exept when i go in the freeway. does any one here knows how to rewire my reverse light cause i did a auto to manual conversion. im in a world of crap right now more to come im workin.... thanks
