code 19
Discussion in 'Civic and CRX - EF' started by goose2, Apr 8, 2008.
  1. goose2
    goose2 New Member
    i have a code 19 on my ecu.lock up control solenoid valve.what is this?
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    it means that you are using an ECU for an automatic transmission car in a car equipped with manual transmission or you you have an automatic transmission car but the lock-up solenoid is not connected
  3. goose2
    goose2 New Member
    it ts an automatic with an auto ecu.when i first put the ecu in the soleniod was disconected and i connected it later.i disconected my battery for 30 min to reset the ecu and the shifter still won't move.it was working fine b4 i disconected it.
  4. BrokenRex
    BrokenRex New Member
    well that's your problem...
    no, seriously, I have no clue about automatics. sorry...
  5. goose2
    goose2 New Member
    well i swaped out the solenoid and it still wont come out of park.both wires have power that go to it.i even swaped ecu's from a pg7 to a pr4.still wont come out of park.
