Code 6 On A Pm6 Ecu
Discussion in 'ECU's, Electronics, and Tuning' started by RFHOMI2U, Jan 27, 2003.
  1. RFHOMI2U
    RFHOMI2U Senior Member
    recently after my z6 swap into my crx si, my PM6 ECU is flashing 6 times. where do i go to get info on what this code means? or can one of you guys help me?
  2. AsiAnVenOm
    AsiAnVenOm Member
    code 6 is the Engine Coolent Temperature (ECT)
  3. D See 2
    D See 2 Senior Member
    Baltimore, MD
    6 Coolant temperature sensor or circuit
    its on the back of the block near the oil filter
  4. D See 2
    Baltimore, MD
    its on the back of the block near the oil filter but dont get it confused with that other one back there, the ECT has two prongs on it the other one back there has 1... BTW, what is that other one... i know its in an oil galley?
  5. hybrid4
    hybrid4 Senior Member
    Nashville,TN
    If your temp sensor is'nt near your oil filter, it is on the thermostat housing. ( Head end of the upper coolant hose.) Some z6's are different than others.
  6. AsiAnVenOm
    AsiAnVenOm Member
    hahahha ect sensor is in the back near the oil filter? hmm...that sounds like you're discribing the knock sensor....i dont know...but engine coolent sensors are usually on the side of the head on toward passenger side...
  7. RFHOMI2U
    Well here's the story. when i was doing the swap, the website i went to said that there would be a two prong sensor on the back of my A6 that i would have to put on the back of the z6. So i did. and the plugs lined up. but on the z6, there is a 2-prong sensor also on the thermostat housing that is not hooked up because there is not a plug for it on my wiring harness. Should i try to run the wires over to that sensor? would that work maybe??
  8. hybrid4
    Nashville,TN
    That should be your coolant temp sensor on your thermo housing. The z6's ive heard have no knock sensor on the outside of the block. They may have one somewhere else, but i know i don't have one. There is one wire on the back of the block that i think is the oil press. sending unit. But, that wire is already on your 4th gen. SI harness, therefore ,it is not the knock sensor. The wire isn't RED, i think its brown. Just extend the 2 wires over to the thermostat and call it a day. :worthy:
