i got a coolant temp error witch is code 6
i check the resistance and the colyage on the wires and the sensor.
everything checked out fine. so why do i still get the code.
my vtec doesnt work because of this
thermostat problems would cause a code 6 to show up? i thought it only related to the coolant temp sensor itself. also, how can you check the wiring to see if it's intact? do you have to follow it from the sensor back? thanks.
