CODE BREAKING TECH
Discussion in 'ECU's, Electronics, and Tuning' started by b16a91crxsi, Dec 26, 2002.
  1. b16a91crxsi
    b16a91crxsi Member
    SEATTLE
    :worthy:
    0 = ECU
    1 = OXYGEN CONTENT
    3 = MAP SENSOR
    5 = MAP SENSOR
    6 = CRANK ANGLE
    7 = THROTTLE ANGLE
    8 = TDC POSITION
    9 = NO. 1 CYLINDER POSITION
    10 = INTAKE AIR TEMP
    12 = EXHAUST GAS RECIRCULATION (EGR) SYSTEM
    13 = ATMOSPERE PRESSURE
    14 = ELECTRONIC AIR CONTROL
    15 = IGNITION OUTPUT SIGNAL
    16 = FUEL INJECTOR
    17 = VEHICLE SPEED SENSOR
    20 = ELECTRONIC LOAD DETECTOR
    22 = VTEC SYSTEM MALFUNCTION
    23 = KNOCK SENSOR
    41 = 02 SENSOR HEATER
    43 = FUEL SUPPLY SYSTEM
    45 = SYSTEM TO RICH OR TO LEAN
    48 = PRIMARY HEATED 02 SENSOR
    54 = CRANKSHAFT SPEED FLUCTUATION SENSOR
    61 = PRIMARY 02 SENSOR CIRCUIT
    63 = SECONDARY 02 SENSOR CIRCUIT
    67 = CATALYST SYSTEM
    70 = AUTOMATIC TRANSAXLE
    71-74 = RANSOM MISFIRE
    80 = EXHAUST GAS RECIRCULATION
    86 = ENGINE COOLANT TEMPERATURE CIRCUIT
    90 = EVAPORATIVE EMISSION CONTROL SYSTEM LEAK DETECTED
    91 = FUEL TANK PRESSURE CIRCUIT
    92 = EVAPORATIVE EMISSION CONTROL SYSTEM INSUFFICIENT
    NOTE: SOME TROUBLE CODES ARE NOT LISTED FOR CERTAIN MODELS AND SOME CODES ONLY APPLY TO CALIFORNIA CARS. :ph34r:
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Also this info is in the articles section which nobody seems to read.
  3. pissedoffsol
    wtf is a ransom misfire? :p
    must be holding it hostage
  4. xj0hnx
    C.C.TX.
    damn terrorist ignition coalition.
  5. b16a91crxsi
    b16a91crxsi Member
    SEATTLE
    LOL, Yeah I'm still new to this site, just trying to be helpful, I actualy got the info out of an old Issue of Honda Tuning, just trying to be helpful.
  6. D See 2
    D See 2 Senior Member
    Baltimore, MD
