EGDriver93
Installed Buddy Club N+ Spec Dampers and the lower mounting point onto the LCA, (the fork) has two aluminum shims for the EK, took those out so the EG bolt would fit, but now the original EG bolt is too small......any suggestions?
It is clicking when I shift through the gears because of the torque on the suspension. It's tight, torqued to spec, but I know that clicking is coming from it.
Should I just buy new bolts in the right diameter from the hardware store? What would you guys do?
