As long as it's not an Si, yes. The throttle body connection on the Si is different... D15B2 faces up while the D16A6 faces to the side. You can adapt it to fit, but it's not going to work as a straight drop in intake replacement. If the intake is for the CRX DX, then it'll work.
i doubt the CAI is off of a dx. ive looked far and wide and nobody makes one for the crx dx and if what i said is the truth, then you will have to add some length to the manifold end of the pipe to make it reach the DPFI manifold.
