Comparing Engines
Discussion in 'HYBRID -> EG-EK / DC' started by drasticdezignz, Jan 15, 2003.
  1. drasticdezignz
    drasticdezignz Member
    I am considering pulling the stock engine out of my 88 CRX DX..
    I would like to know if swapping in a d16A1, or d16a3 engine is similiar to the ZC engine swap. The D16 was located in the USDM Integra, while the ZC in the JDM. The only difference I have been able to determine is that the ZC's compression ratio is higher than the D16. What I want to know is; is if the D16 will be similar to the ZC installation [motor mounts, wiring, tranny, and ECU]
    Thanks...
  2. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    The D16A1/3 doesn't bolt into a 4g civic/2g CRX. The mounts are off, and the 80s Integras are the only D series engines that are incompatible with the rest. But the wiring would be exactly the same. BTW, the difference is in piston dome, head spec, and cams.
    *EDIT--and IM
  3. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Got a DOHC ZC complete swap for sale. Look in the classifieds section if interested. $700 for complete swap.
