Completely puzzling.
Discussion in 'Integra' started by teamjdm239, Jan 29, 2009.
  1. teamjdm239
    teamjdm239 professional driver
    lil pakistan, 239-florida
    ok, i have a ls/vtec integra at my vocational school thats being really confusing, its idle fluctuates from 3000 down to1000 back to 3000 and so forth. i was pretty sure it was the iacv , but i put a different one in, and its still doing the same thing, then i checked for vaccum leaks with a smoke machine, it has none, i then bridged the obd1 plug to see if it would throw a code, my luck , it didnt. im completely puzzled, maybe someone can help.:confused:
  2. George777
    George777 ^^ Likes Bewbies
    With your mom
    Did you check your coolant level? Are there air bubbles in the coolant system?
  3. teamjdm239
    coolant level is good, and there are no bubbles.
  4. eg6sir
    there is a thread on this right now... read up
  5. teamjdm239
    it was the thermo valve,
  6. bluerex504
    bluerex504 New Member
    I was just gonna say that.
  7. maxbodyworks
    maxbodyworks maxbodyworks
    Las Vegas
    how is the alternator,.....do you have an amp on you stereo sys.....it might be starving for power,....check your ign.module(igniter)
  8. George777
    With your mom
    Reading > You
