Compression And Timing
Discussion in 'Engine Building' started by 96hatch, Feb 5, 2003.
  1. 96hatch
    96hatch Junior Member
    I am building a lsvtec / stock b16 head with 11.5 c/r and i was wondering if there are any timing adjustment
    ( or any adjusments) to be made before i drive it ?
    will the stock b16 ecu work with the set up?
    thanks guys
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Which B16 ECU? I assume you are putting this engine into a 96 Civic Hatch (you name) if not which chassis is it going into?
    I ran 11.5:1 on stock ignition timing no problems.
  3. 96hatch
    thanks for the quick reply, it is a 99 b16 ecu
    so you think the stock ign, and timing would work?
    does extra fuel need to be added?
    thanks
  4. lsvtec
    I am not sure if you need to add fuel pressure with the B16 ECU, but I bet not. If anyone knows different, please correct me.
    I know the stock ignition timing works with an OBD1 P72 ECU/Distributor. As for stock ignition parts, they will work great.
